I am working on a pre-built project on ecockpit and facing these build errors, is this can be because of library is not up-to date? i am clueless on how to investigate this issue.
In one of the declared variables i have this following statement which i believe might be the source of it.
oCanRx11BitStatus : WagoSysErrorBase.FbResult;
Please let me know how to approach this problem. Thanks.
You should add information about version of e!COCKPIT, device FW and PLC type you have in the project
It seems that WagoSysErrorBase is in version 1.6.2.5, which is not compatible with WagoTypesErrorBase in version 1.6.0.0. WagoSysErrorBase needs I_ResultProperties from WagoTypesErrorBase
Just choose from “Placeholders” newer version of WagoTypesErrorBase (eg 1.6.2.0)
