I got a little bored with the error messages in /etc/WAGO_LOGIN dmidecode and ifconfig not found. So Iβve updated it a bit. If Wago wants to use it, please do it.
#!/bin/sh
# Check for screenfetch and run it if present
if command -v screenfetch >/dev/null 2>&1; then
screenfetch
fi
# Check and fetch system version
if [ -f "/sys/class/dmi/id/product_version" ]; then
VERSION=$(cat /sys/class/dmi/id/product_version)
else
VERSION="Version not found"
fi
# Fetch IP addresses
IP_LAN1=$(ip -f inet addr show X1 2>/dev/null | grep -oP 'inet \K[\d.]+')
IP_LAN2=$(ip -f inet addr show X2 2>/dev/null | grep -oP 'inet \K[\d.]+')
TAILSCALE=$(ip -f inet addr show tailscale0 2>/dev/null | grep -oP 'inet \K[\d.]+')
# Gateway, DNS, and NTP information
GATEWAY=$(ip route | grep default | awk '{print $3}')
DNS=$(grep "nameserver" /etc/resolv.conf | awk '{print $2}')
NTP_STATUS=$(timedatectl status | grep "NTP service" | awk '{print $3}')
HOSTNAME=$(hostname -f)
# Display ASCII Art Banner and other information
echo "\033[1;32m
ββ ββ βββββ ββββββ ββββββ
ββ ββ ββ ββ ββ ββ ββ
ββ β ββ βββββββ ββ βββ ββ ββ
ββ βββ ββ ββ ββ ββ ββ ββ ββ
βββ βββ ββ ββ ββββββ ββββββ
\033[0m"
if [ "${VERSION}" != "Version not found" ]; then
echo "Product-Info: ${VERSION}"
fi
# Display URLs with IP check and conditional Tailscale IP display
echo "
Cockpit console: https://${HOSTNAME}:9090/$( [ -n "${IP_LAN1}" ] && echo " or https://${IP_LAN1}:9090/")
Portainer console: https://${HOSTNAME}:9443/$( [ -n "${IP_LAN2}" ] && echo " or https://${IP_LAN2}:9443/")
X1: ${IP_LAN1}
X2: ${IP_LAN2}"
[ -n "${TAILSCALE}" ] && echo " Tailscale: ${TAILSCALE}"
echo " Default Gateway: ${GATEWAY}
DNS Server: ${DNS}
NTP Service: ${NTP_STATUS}"
A other version
#!/bin/bash
# Initialize service status variables
COCKPIT_ACTIVE="inactive"
PORTAINER_ACTIVE="inactive"
ISSUE_FILE_COCKPIT="/etc/issue.d/cockpit.issue" # Ensure this path is correct
screenfetch
fi
VERSION=$(cat /sys/class/dmi/id/product_version 2>/dev/null || echo "Version not found")
echo -e "\033[1;32m
\033[0m"
echo -e "\033[1;32m
\033[0m"
echo -e "\033[1;32m
\033[0m"
# List all network interfaces except lo and those without an IP or with only local IPs
echo -e "Available network interfaces and their IPs:"
echo "==========================================="
for iface in $(ip -o link show | awk -F ': ' '{print $2}' | cut -d' ' -f1); do
# Fetch IP address, exclude empty, localhost, and virtual interfaces like veth*, docker*, etc.
ip=$(ip -f inet addr show $iface 2>/dev/null | grep -oP 'inet \K[\d.]+')
if [[ -n "$ip" && "$iface" != "lo" && ! "$iface" =~ ^(docker|veth|br-).* ]]; then
echo -e " $iface: \033[1;37m$ip\033[0m" # IP addresses displayed in white
fi
done
echo " "
# Check for Cockpit service status
if [ -f "$ISSUE_FILE_COCKPIT" ]; then
echo "Cockpit is installed."
COCKPIT_ACTIVE="active"
# Read and display the URL from the issue file
echo "Reading web console URL from $ISSUE_FILE_COCKPIT:"
cat "$ISSUE_FILE_COCKPIT"
else
echo "Cockpit is not installed."
COCKPIT_ACTIVE="not installed"
fi
echo -e "Cockpit Status: \033[1;32m$COCKPIT_ACTIVE\033[0m"
[ "$COCKPIT_ACTIVE" = "active" ] && echo "Cockpit console: https://${HOSTNAME}:9090/"
echo " "
# Check for Portainer service status using Docker
if command -v docker >/dev/null 2>&1; then
if docker info >/dev/null 2>&1; then
if docker ps | grep -q portainer; then
PORTAINER_ACTIVE="active"
else
PORTAINER_ACTIVE="inactive (Docker running but Portainer not found)"
fi
else
PORTAINER_ACTIVE="Docker permission denied or not running"
fi
else
PORTAINER_ACTIVE="Docker not installed"
fi
echo -e "Portainer Status: \033[1;32m$PORTAINER_ACTIVE\033[0m"
[ "$PORTAINER_ACTIVE" = "active" ] && echo "Portainer console: https://${HOSTNAME}:9443/"
# Check for ignition scada and run it if present
if command -v /usr/local/bin/ignition/ignition.sh status >/dev/null 2>&1; then
fi
# Tailscale IP address
TAILSCALE_IP=$(ip -f inet addr show tailscale0 2>/dev/null | grep -oP 'inet \K[\d.]+')
DNS=$(grep "nameserver" /etc/resolv.conf | awk '{print $2}' | xargs)
# Display other information
echo -e "
Product-Info: \033[1;37m$VERSION\033[0m
Tailscale IP: \033[1;37m${TAILSCALE_IP:-Not available}\033[0m
Default Gateway: \033[1;37m$GATEWAY\033[0m
DNS Server: \033[1;37m$DNS\033[0m
NTP Service: \033[1;37m$NTP_STATUS\033[0m
